Farmall Tractors Discussion Board
Re: Cub carb leaking gas !
Posted by Wooden Shoe on December 15, 1999 at 04:45:29 from (205.188.192.178):
In Reply to: Cub carb leaking gas ! posted by C.Fitz on December 14, 1999 at 19:56:17:
If the fuel is comming from the bottom of the carb look for anything that threads in to the bowel itself. Usually you can seal threads with a small amount of pipe joint compound. If the Carb is overfilling and you suspect the needle and seat remove the bowel and check the seat for condition and any foreign material. You may want to inspect the bowl gasket carefully it can leak out fuel by splashing. Also carb floats a lot of the time are made of brass and they can sink. To check, shake and listen for fuel in them. Also dry them with a clean dry cloth and look for fuel "bleeding" out of seams or anywhere on the floats. If you still haven't found anything Maybe it a good idea to replace the needle and seat and recheck float level.
Post A Followup
: Re: Re: Cub carb leaking gas !
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
