Re: Farmall M brake ?
Posted by kfox on June 13, 2005 at 19:46:48 from (63.18.185.127):
In Reply to: Farmall M brake ? posted by TWL on June 13, 2005 at 16:27:33:
If you need to replace the bearing housing, you have a little work to do. I broke the bearing housing on my H the same way you broke yours. I think the H & M are put togather about the same, so here's what I had to do. Remove the axel housing & axel, top transmission cover (ugg), and the bullgear.The brake bearing housing catches behind the bullgear, and it won't come out with the bullgear in place. On the H, I had to rotate the brake bearing housing a little to get the bullgear out & back in. Don't know if the M is the same. the bearing housing has a O-ring around it, and my broken housing had a cork O-ring, but the replacement I got from the boneyard had a rubber O-ring that was still useable. Hope this helps, and good luck. ken
Post a Followup
