Re: Where's it go??
Posted by Janicholson on June 14, 2005 at 09:16:33 from (199.17.6.127):
In Reply to: Re: Where's it go?? posted by Cmore on June 14, 2005 at 08:34:09:
Letter farmalls, and others use linkage to the govenor that has no lubricant on the pivot points. these become worn and allow the rods to lengthen. The govenor will prevent overspeeding internally. look to the rods/joints and adjustments so that the govenor control lever is pulled fully when the hand control lever is in its last notch. On Cs there is also an external rod link from the gov. to the carb. this is not the linkage with the problem, do not adjust this except with a manual to go by. Ill bet the engine stays at idle till the hand lever is more than i/2 way pulled. LOL let us know the fix that works.
JimN
Post a Followup
