Re: Farmall M brake ?
Posted by Haas on June 14, 2005 at 19:10:45 from (12.65.0.214):
In Reply to: Re: Farmall M brake ? posted by TWL on June 13, 2005 at 17:14:34:
You made the same mistake many have before you. That bearing housing is a cage on the inside that supports the pinion shaft bearings and the pinion gear is on the inside of it. It can't be removed without taking the bull gear off the shaft and letting the bull gear drop down out of the pinion cage slot that the bull gear runs in. Pulling on the flange without removing the bull gear results in much grief as you have found out. You do not need to remove this cage (as others said) to replace the pinion seals. The seals run on the brake drum hub, so once you pull the brake drum off the pinion shaft, you can pry out the old seal and press in a new one. Hope you are able to get it fixed, but it's going to be a pretty big job now that the pinion housing is broken. Good luck, and you are not the first one to do this.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
