Re: Trouble with v-belt for Woods L59 under Farmal
Posted by Bill Geer on June 14, 2005 at 21:49:36 from (216.157.203.35):
In Reply to: Trouble with v-belt for Woods L59 under Farmall A posted by Tara Sullivan on June 13, 2005 at 18:17:20:
Tara
This is from a l59 manual
1. first put belt on bottom grove,right hand side of the center sheave.Then thread it to the left,around the left hand sheave.
2.Bring the belt back across the center groove over to the right outside sheave.
3. Then thread it back across the frount of the center aheave in the top groove.
4. PROPER TWIST The belt then follows with a 3/4 twist back under the left v-idler,up over the drive sheave and back down under the right idler pulley. This will leave a 1/4 twist in the section of belt extending from the right v-idler to to lower groove of the center mower sheave.
5. Adjust the mower to proper cutting height.The front of the mower should be slighty lower than the rear for best cutting and least power requirement.
6. IDLER ADJUSTMENT Make minor belt adjustments with idlers but keep left idler about 1" above being in line with the groove in witch the belt runson the center sheave of the mower and right idler 1" below. Move mower fore and aft for major adjustments.
This is good for modles 59c,l59,& L306.
If I knew how I would send some pics.If you need pics e-msil me and I will see if one of my kids will send them. Hope this helps Bill,
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
