Re: McCormick Deering Super W-4 Starting Problems
Posted by EricB on June 15, 2005 at 09:28:06 from (216.209.84.11):
In Reply to: McCormick Deering Super W-4 Starting Problems posted by Bill Carlton on June 15, 2005 at 08:15:18:
Bill:
Nat mentioned a failing starter switch. This is a very strong posability. To test this use a jumper cable and go directly from the battery to the starter terminal, bypassing the switch.
ALWAYS CHECK to make sure the tractor is in NEUTRAL. (I spent 2 wks in hospital when I forgot that and almost killed myself)
Note: If you have to change the starter, you will need to remove the belt drive housing. There are 6 bolts to do this. It usually can slide out of the way sufficiently so you don;t have to lift it right off. R&R for the starter is about 25 minutes.
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
