Re: Need Elect. HELP - Attn: Bob M Others
Posted by Bob M on June 16, 2005 at 04:16:45 from (151.190.254.107):
In Reply to: Need Elect. HELP - Attn: Bob M Others posted by BIG JOHN on June 15, 2005 at 19:11:26:
Big John – Has your MV been converted to 12 volts? Does it have a solenoid starter switch?
If it does, problem is likely the ballast resistor is not being bypassed by the solenoid when cranking. (In addition to the wire from the ignition switch to the coil “+” terminal, there should also be a wire running from the solenoid “I” terminal to the coil “+”)
If it’s 12 volt and has the original mechanical starter switch problem could be too high resistance in the ballast resistor (try shorting the resistor while cranking) or a failing coil.
Or if it’s still the stock 6 volt system, it’s likely you’ve got a weak coil.
Loren – The MV is a high ground clearance M – sort of an “M on stilts” .
Post a Followup
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
