Re: cub oil pressure
Posted by Karl Z. on June 18, 2005 at 20:07:16 from (64.12.117.13):
In Reply to: cub oil pressure posted by billde on June 18, 2005 at 19:46:15:
I'm pretty sure the Cub has a bypass oil filter so if it's clogged it won't have any affect. I'd start by checking the oil pressure gauge by replacing it with a one you know is good. Then I'd check the oil pressure relief valve. It's located on the right side of the engine just under the magneto drive. Unscrew the plug and remove the spring and plunger. Make sure the plunger is clean and can slide easily in the hole. Also, check the spring for proper tension. If all of that checks out then I'd drop the oil pan and look for restrictions in the oil pickup or sludge in the pan. Finally, if none of those fix the problem, you're left with spliting the tractor and replacing the oil pump on the back of the block. Hopefully, it will be something easy and inexpensive to fix.
Post a Followup
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
