Re: Hydraulic coupler block on 656
Posted by Hayfarmer on June 18, 2005 at 21:45:39 from (12.160.171.138):
In Reply to: Re: Hydraulic coupler block on 656 posted by El Toro on June 18, 2005 at 09:08:08:
Not too sure why it stopped. I took the coupler off to see what was behind it. hard to tell where the line actually ended but couldn't see any way to get it out. Put coupler back on the fitting behind it was the O ring yype where you tighten up the inside then tighten a nut against the O ring to seal. Afterwords got some air from next to the line and it quit leaking. Maybe the coupler fitting puts pressure against the line to make it seal.
Post a Followup
