Re: super m water in oil
Posted by El Toro on June 19, 2005 at 19:10:29 from (205.188.117.73):
In Reply to: super m water in oil posted by williams on June 19, 2005 at 18:07:15:
You need to get a sleeve puller, your local rental shop may have a puller. Your local machine shop can machine a puck. You need the
block bore dimension and the piston too and have it machined to fit just inside the sleeve and enough clearance to clear the block. .020" under
the piston diameter and .040" to .045" overall for the puck to clear the block. Hal
PS: You need a 13/16" hole in the center for 3/4"
allthread.
Post a Followup
