Re: 300 hydraulic pump rebuild
Posted by George Mikesell on June 19, 2005 at 21:58:52 from (209.42.79.128):
In Reply to: 300 hydraulic pump rebuild posted by jmyt_47 on August 16, 2001 at 08:06:55:
Your pump has no gaskets internally, it does have two orings on brass backing pkates, and one on outer case, you can get orings at about any parts store and or buy kit to make your own,Seals also can be gotten at parts stores. As long as your gears are not scored, and the backing plates if scored can be surfaced on piece of glass or flat metal, with 180 grit wet dry paper. The major problem is if the spring backing plate is applying enough tension on brass backing plates to keep pump from bleeding by. If this is a problem you can put in .030 spacer which you have to cut out of brass shim stock or steel. No one provides this it is a home job. It has been my experience that the backing plates get weak over time and need some help, sure wished could buy new ones. Any way this will usually put the pump where it will produce 12-1500 lbs pressure.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
