Re: Scratching my Sunburned head in frustration
Posted by FC on June 20, 2005 at 11:01:03 from (64.141.134.66):
In Reply to: Scratching my Sunburned head in frustration posted by Scott Swanson on June 20, 2005 at 09:14:32:
Look for something else that could be causing the problem - sometimes the problem is not very obvious. Example - I removed a transmission and replaced a clutch on a truck and when I put everything back it would not start. How could removing a trans and replacing the clutch cause it not to start? The simple fact was that I pinched a wire going to the fuel pump and blew the fuse. I could have spent days trying to find the problem, but I discovered the blown fuse rather quickly which kind of gave me an indication that I had shorted something out. I know this may not help much, but sometimes you have to look beyond the obvious. Good luck - I know your frustration.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
