Re: International 354 amp light
Posted by Van in AR on June 20, 2005 at 11:03:20 from (216.134.231.237):
In Reply to: Re: International 354 amp light posted by Mike Siless on June 20, 2005 at 09:23:43:
Shouldn't need to be repolerized, Check the regulator mounting and make sure it is tight and grounded to shiney metal. The regulator if like mine (a Lucas) will have to be removed to take the cover off. They are sealed with metal fingers around the base and are a PITA, be carefull and it should come apart easy. The wires look permanent on first inspection but plug in the bottem seperately, don't get them mixed up and you should be fine.
Van
Post a Followup
