Re: C hyd-pump
Posted by CNKS on June 22, 2005 at 06:00:22 from (204.249.178.138):
In Reply to: C hyd-pump posted by LarryW-Tx on June 21, 2005 at 21:31:38:
If youhave a parts book you can give your dealer the number, it is in his computer -- he will probably have that o-ring on the shelf as it has multiple applications. Bear in mind that if there is a groove in the shaft that you will need a speedy sleeve. You will have to have the shaft hole enlarged to accept the speedy sleeve. CIH still has a kit available for that pump -- but again you need the number as there is more than one pump.
Post a Followup
