Re: Spun bearing
Posted by El Toro on June 22, 2005 at 06:24:49 from (64.12.117.13):
In Reply to: Re: Spun bearing posted by Johann on June 22, 2005 at 06:09:01:
Since you have the engine removed I would have the block degreased and have all the oil passages
cleaned so everything is free of any metal shavings.
You should have that crankshaft measured at your
local auto machine shop to see if std. or undersize inserts are required. I would replace all of them with new bearings.
You also should clean that oil pump and any other component that may have some metal shavings.
Your oil pump circulates the oil throughout the engine and needs to be free of any foreign material. Hal
Post a Followup
