Re: Spun bearing
Posted by captaink on June 22, 2005 at 07:24:51 from (66.115.214.56):
In Reply to: Spun bearing posted by Johann on June 22, 2005 at 04:55:50:
I’ll give you a few thoughts to ponder as you make your decision. First and foremost I believe is to determine why that bearing spun. You noted that you suppose that it was not installed correctly, but you really need to make sure. I say this because I found a spun bearing in an engine once and came to find out that it had a cracked block and anti-freeze was getting into the oil. The bearing was put in correctly, but I believe that since this was in a low usage engine the antifreeze caused the bearing to “stick” once and then it spun. I would suggest you have the rods checked at a machine shop to make sure that the bearing area in the rod is not out of round or otherwise distorted. Those freckle faced bearings are that way from foreign material being imbedded into the soft bearing material. This foreign material was pumped throughout the engine including the cam bearings and oil pump. If only the softer bearing material was in the oil, there was probably no damage to the pump or other steel parts like the crankshaft, but if some of the backing shell of the bearing came loose, then harder steel filings may have caused damage elsewhere in the engine. Another thing to consider is that there may still be pieces of foreign material floating around in the oil galleys somewhere. I would also be suspect of the camshaft bearings looking like the crankshaft bearings. I strongly suggest (especially if this is a newer rebuild) that you completely tear the engine back down and thoroughly clean and inspect the parts especially the cam bearings for filings or have it done at a machine shop. I would also strongly recommend having the crankshaft at least polished by a machine shop to ensure that there are no nicks in it from the material passing through it. I would consider these expenses cheap insurance so that your engine runs a long time after you are done. I had a bad experience once when I tired to “cut a corner” on an engine rebuild and lived to regret it…I like working on engines but not enough to do it over again right away! :>) My nickels worth…good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
