Re: Rim Color
Posted by Cue P. on June 24, 2005 at 09:09:49 from (66.236.176.98):
In Reply to: Rim Color posted by Double-R on June 24, 2005 at 08:49:51:
I believe they should be bright aluminum. I used rustoleum on my W4 and it turned out ok. Trick is to do good prep, clean surface and good primer. Aluminum paint is very thin. Besides a primer I put a thick coat of rustoleum gray, sanded, then added two coats of aluminum, sanding between each coat. Been a year and no problems.
Post a Followup
