Re: oil pressure revisited
Posted by CNKS on June 24, 2005 at 19:05:31 from (204.249.178.138):
In Reply to: oil pressure revisited posted by Paul Shuler on June 24, 2005 at 15:36:34:
If it has oil pressure in the center or upper part of the gauge at full throttle, and that pressure does not drop much when it has been run an hour or so, I wouldn't worry about the idle pressure. I have a Super A that runs in the lower third of the gauge at full throttle when hot, I don't pay any attention to the idle pressure. It is on my list to overhaul, I don't think yours is. You will know when -- for one thing you will have excess smoke out the breather, and it will be using oil.
Post a Followup
