Re: Shifting trouble
Posted by Janicholson on June 25, 2005 at 18:08:22 from (66.173.50.75):
In Reply to: Shifting trouble posted by Steve Metz on June 25, 2005 at 08:51:58:
I make the assumption that the clutch is not draging, and being held down sufficiently. There are three items of interest in order of easy to check/fix: The shifter lever tip on the far end of the lever in the little tower on the platform is worn in a way that hangs up. Repair by disassembling the lever from the tower and welding up and reshaping. The shift rails and detent balls are worn and or bent causing grief in getting it out of gear. Trans cover (platform) has to be removed to repair. Gear has worn the splines on its shaft (or teeth, less likely) and these symetrical ridges are making the gear reluctant to move on the shaft. Correcting means tear down to replace worn parts. Some try to bevel the wear by dremel grinding, but this still requires the teardown to get access. Not the real solution. Others may post more possibilities. Good luck, Jim Nicholson
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
