Re: Super H brakes dont work
Posted by DWV on June 26, 2005 at 08:15:12 from (152.163.101.13):
In Reply to: Re: Super H brakes dont work posted by ChadS on June 26, 2005 at 07:25:25:
Take the outside brake housing lay it down and place new brake shoes or measure new shoe thickness and use that figure along with actuator
inside brake housing.Place flat edge across housing and check clearance between housing and
shoe.Measure brake back plate and check where the
shoes hit,is it raised or concaved compared to surface that brake housing bolts to,add or subtract from previous measurement.If clearance
is excessive machine inside edge of brake housing.Also Machine any parts that need trued up before measuring.Also check splines for excessive
wear and make sure actuator linkage is not hitting inside brake housing.Hope this is understandable.
Post a Followup
