Re: Seals for Brake shaft on H
Posted by CNKS on June 27, 2005 at 11:44:05 from (204.249.178.138):
In Reply to: Seals for Brake shaft on H posted by marvin on June 26, 2005 at 21:30:56:
No tricks, use a block of wood or a socket if you have one that fits, I just use the wood. That is an IH number -- Other numbers for the same seal are 358777 R91 and 360252 R91. The current IH seal may have a different number -- doesn't matter as your dealers computer will cross it to the correct number. A seal/bearing place will cross it also. You can put 2 on each side if you want, but the new seals are far better than the leather ones that came on your tractor.
Post a Followup
