Re: M's hydraulic system
Posted by williamf on June 27, 2005 at 17:33:06 from (66.82.9.90):
In Reply to: M's hydraulic system posted by Kevin Brooks on June 27, 2005 at 15:26:54:
I'm guessing you're talking about the cover that is to the rear of the hydraulic unit.(BTW, the trade name IH used for that unit is "Liftall.") There's a much smaller cover forward of the Liftall that is access to a grease zirk on the clutch release bearing. The cover to which I believe you refer allows access to the clutch drive shaft and the Liftall drive shaft. It should be dry in there; whatever is leaking out had to first leak from somewhere else. It could be coming from the Liftall or the transmission. Or both. There's a drain for the Liftall slightly forward of that cover, on the bottom of the Liftall unit. Probably a square head plug, about 3/4 inch. The Liftall was designed to use 30wt nondetergent motor oil. A lot of people have switched to regular hydraulic oil. If you're not using the hydraulics on your tractor you can easily uncouple the Liftall drive shaft and drain it. Owner's Manual and Service Manual are readily available and all but indispensible. Good luck, Wm
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
