Re: SA rear axle seals replacement crank pully
Posted by VAJerry on June 28, 2005 at 07:05:06 from (207.78.118.64):
In Reply to: SA rear axel seals replacement crank pully posted by scott#2 on June 28, 2005 at 06:54:13:
Pull it all the way down. Replace all the seals. I'm just a little a head of you. If your using electrolysis the drives can go in the tank then. And you will be able to check the bearings. 50 years they need to be checked. And the seals on the tranny at the axle should be replaced. All are still available from IH.
Post a Followup
