Re: SA rear axel seals replacement crank pully
Posted by VAJerry on June 28, 2005 at 07:09:21 from (207.78.118.64):
In Reply to: SA rear axel seals replacement crank pully posted by scott#2 on June 28, 2005 at 06:54:13:
I used a wheel puller. Tigheten it up a few wacks tighten some more a few wacks (on the bolt on the puller not the pulley). Some have had to use heat. And I did bend my cheap puller.
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
