Re: SA rear axel seals replacement crank pully
Posted by Dixieland on June 28, 2005 at 16:11:15 from (69.179.197.59):
In Reply to: SA rear axel seals replacement crank pully posted by scott#2 on June 28, 2005 at 06:54:13:
Whoa there Scott! You can break that front pully if you are not careful. There is a set screw and it is behind the pully. Remove the set screw first and Place a bearing puller behind the pully and catch hold of the bearing puller with a three point puller. If you try using just a three point you can break your pully and they ain't cheap.
Good Luck.
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
