Re: C Carb.. Need Help!!
Posted by 504 on June 28, 2005 at 19:52:49 from (38.119.116.74):
In Reply to: C Carb.. Need Help!! posted by K-Mo on June 27, 2005 at 17:11:53:
K-MO,I just went thourgh this with a 504. The needle valve doesn`t have enough side clearance between the valve and the seat,a small file and some emery cloth and it will stop the leak.I can not take credit for this fix,I got it from an old carburetor man in town.I almost fogot, make sure that the wire clip that holds the needle valve to the float is there and hooked up. kjm
Post a Followup
