Re: H tune-up advice.
Posted by riverbend on June 29, 2005 at 06:44:14 from (208.160.34.21):
In Reply to: Re: H tune-up advice. posted by VanO on June 29, 2005 at 05:20:29:
Get an Operator's manual. It tells how to set the timing, and more important, where and how often to service and grease your tractor.
Use the notch that is at TDC. The difference in fuel does matter with these motors. Advancing the timing will just make it harder to start. Use lighter springs in the autoadvance to make the curve steeper.
Post a Followup
