Re: super A generator wiring
Posted by Hugh MacKay on June 29, 2005 at 07:49:57 from (209.226.247.10):
In Reply to: Re: super A generator wiring posted by phil W in Michigan on June 29, 2005 at 06:55:43:
Phil: I have 3 conversions here, 1953 SA, 130 and 140. These tractors are very easy to convert. I just welded a flat plate on top of current generator mount, then a couple of tabs for mounting Delco alternator. The pulley I use is double V off the older GM V8 engines. Use the V farterest from alternator. This allows you to set alternator lower and tuck it in closer to engine block, makes for a neater looking job. My Super A is alternator and is still 6 volt. You can change the built in regulator on the Delco alternator for either 6 volt or 12 volt. This requires no change on tractor. You will have an extra wire in harness, I use that for exciting alternator. I have a starter type push button switch on dash to excite alternator. With that no danger of leaving it on and draining battery when tractor is not running. I like this better than my 12 volt conversions as I have big amperage charging and still 6 volt. If you go to 12 volt then you must change the lights, change coil or add a resistor, then add devices for exciting alternator, etc. Under Articles go to article by Bob M and his wiring diagrams. He will be very helpful should you need it. On my 130 and 140, I needed new lights so I just bought 12 volt. I changed my coils to 12 volt with built in resistor. Only good source for those I've found is CaseIH. I still use the push button on these for exciting the alternator. I tried the light as in Bob's diagram. I couldn't get the exact light Bob called for thus I had poor success. If I can be of any more help, my e mail is exposed. Remember also, I may not be far away, just north of Strathroy ON if you want to have a look at my tractors.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
