Attention Janicholson
Posted by Nositri on June 29, 2005 at 16:00:47 from (24.154.170.29):
Jim,
I tried relubing the starter, but I didn't try cleaning it because I don't have any electrical cleaner. The starter spins up when it is off the tractor, and when I take the starter off after it is grinding the gear is all the way at the end where it should be engaged with the ring gear, but all I get is grinding and grinding when it's in. My ring gear really doesn't look that worn and no teeth are broken. When I push the button I get a grinding sound. Do you think that the battery is too weak causing it to not spin all the way up through the teeth of the ring gear. Any info would be great on this. I just got the fuel system all cleaned and the carburetor functioning correctly and everything adjusted and timed and she sounds good and after all that now she won't start. How do you like life?
Post a Followup
