Re: Farmall M Steering
Posted by Nat on July 01, 2005 at 10:41:53 from (64.80.110.44):
In Reply to: Farmall M Steering posted by LBS on July 01, 2005 at 07:16:00:
It ain't the tires. It's weight of the loader that makes the tractor hard to steer.
You've got three options:
1. Take the loader off. It'll still be hard to steer, but not as much.
2. Get a power steering kit. This will likely cost as much as the tractor is worth. They are a highly prized option, difficult to find used, and even more expensive if you use new parts.
3. Live with it. I suggest weight training to muscle up for the road ahead :)
Post a Followup
