Re: clacking sound / burned glow plugs
Posted by BABOS on July 02, 2005 at 10:02:58 from (24.114.44.75):
In Reply to: Re: clacking sound / burned glow plugs posted by jossette on July 02, 2005 at 06:47:04:
The tractor is a b275 IH. New liners, pistons, pins , rings, pins, rod bearings (good clearances) and a reconitioned head with valves installed. The sound is loudest at the #1 injector, with none anywhere else in the engine. Changed injector with no difference. Checked piston to head clearance and found it ok. Pre-cups are new and have clearance to the piston. Rotated injection pump both ways and is quieter one way than the other , but the noise will not disappear. Cold engine no noise at any rpms, but at operating temps, idle none, 1200-1500 rpm is loudest clacking and from 1700 and up noise can bearly be heard at all. Load has little effect on the sound.
Ron
Post a Followup
