Re: Farmall C Touch-Control Hydraulic Problem
Posted by Farmall Bob on April 06, 2009 at 16:24:22 from (24.31.158.92):
In Reply to: Re: Farmall C Touch-Control Hydraulic Problem posted by Farmall Bob on April 06, 2009 at 16:04:14:
Hi Russ,
I just checked my parts manual. The "O" Rings are called seals, and it doesn't actually show them on or in the groves. Are you sure you replaced everything back the way it came off? There is a Front Check Valve, and a Rear Check Valve. It has been a long time since I had mine apart So I may not be much help. Hopefully some here will spread a little more light on this.
Bob
