Re: 300 Trans / PTO Oil (What kind)
Posted by Dick Davis on July 03, 2005 at 04:12:29 from (152.163.101.13):
In Reply to: Re: 300 Trans / PTO Oil (What kind) posted by Jon Older on July 02, 2005 at 18:24:38:
This has been answered before, but.. The SMTA/ 300/400 were manufactured before IHC got the correct lube figured out for TA equiped tractors. The manual calls for heavy gear lube, later IHC called for a Trademarked "additive" to make it work better, followed shortly thereafter by the introduction of Hy Tran which superceeded both the gear lube and additive. So Hy Tran is the latest/current Trans fluid. Note if you are changing to Hy Tran from heavy lube stand by for posible leaks. My nickel Dick Davis
Post a Followup
