Re: Closed center hydraulics in 86 series ?
Posted by JakeF on July 03, 2005 at 23:33:34 from (64.146.188.222):
In Reply to: Re: Closed center hydraulics in 86 series ? posted by McDiesel on July 02, 2005 at 22:29:59:
We had a 1486 with them. They had an extra hyd filter under the engine. Our 1486 came with a DT-466 and was at 200 PTO HP. It was the poorest tractor we ever owned. We had nothing but trouble with the hydraulic system, lost a rear end, ect. When we traded it off at 6500hrs on the magnum we had gone through everything but the motor, and spent about as much as the magnum cost on repairs. The three point was the worst, it would screw up every fall when we started plowing with the 145 hyd reset roll over plow. Jake
Post a Followup
