Re: SC Clutch problems - Continued:
Posted by Peabody on July 04, 2005 at 05:14:23 from (205.188.117.73):
In Reply to: SC Clutch problems - Continued: posted by skycarp on July 04, 2005 at 04:58:16:
The IT manual gives a "terse" but good play-by-play on splitting & replacing the clutch. It's not a major operation as long as you have or improvise the right equipment. I used a movable engine lift to support the engine and a rolling drum rack & blocking to support the rear. Unbolted, rolled rear end straight back,replaced flywheel ring gear, replaced clutch, pilot & throwout bearing,& put the two ends back together. The whole process took two of us less than two hours. Good luck!
Post a Followup
