Re: IH Super W6
Posted by Paul in Mich on July 04, 2005 at 15:57:10 from (205.188.117.73):
In Reply to: IH Super W6 posted by JaredM on July 04, 2005 at 15:24:43:
Jared, while I am not a puller myself, I have seen lots of W series set up as pullers and they perform quite will against their counterparts. The weight is similar to the row crop equivalants, and while they concede rear wheel diameter, they are usually equipped with wider tread tires which enhances the traction. Since the W-6 is geared the same as the M, its ground speed is lessened somewhat by the smaller rear wheel diameter which gives it more HP relative to ground speed. Since pulling is a combination of HP and traction relative to the weight of the tractor vs the weight of the sled, it comes down to operator esperience and ability, and the ability to tweak the wieght distribution and Horse power, along with getting maximum traction from the tires. From talking to others, half the fun and enjoyment of pulling is in tweaking the tractor to get maximum performance within the given parameters. That also means getting better as an operator. Knowing that you got all there is to get out of the horse power provided by the tractor, all the traction to be gotten with the tires you have, and knowing how and where to set the weights, and how to get a few extra feet of pull when there isnt an inch more to be had is what makes pulling attractive to many people. I suppose the trophies are nice too, but then which bowling trophy are you planning to remove to make room?
Post a Followup
