Re: IH Super W6
Posted by Harold H on July 04, 2005 at 17:02:06 from (67.140.119.73):
In Reply to: IH Super W6 posted by JaredM on July 04, 2005 at 15:24:43:
These are the Nebraska Test results for the Super W-6 gasoline. Test #476, max hp belt 46.25, max hp db 41.57, max pull 5663 lbs @ 2.49 mph, corrected hp 48.77 max belt, 43.71 max db. Weight as tested with operator 9137 lbs. Nebraska test weight with no ballast 5515 lbs. Speeds from specs: 1st 2.58, 2nd 3.68, 3rd 4.78, 4th 6.58, & 5th 16.15. Shipping weight 5115 lbs in specs. Actual weight when delivered at Nebraska was 400 lbs more than advertised weight but that weight included operator so tractor was actually probably about 200 lbs heavier than advertised.
Harold H
Post a Followup
