Re: 460D Injection Pump Timing
Posted by Ron Smith on July 05, 2005 at 14:54:31 from (207.200.116.203):
In Reply to: Re: 460D Injection Pump Timing posted by Aces on July 05, 2005 at 05:08:37:
From what I have read, I am looking for the spot where the cylinder is up (TDC)and both of the valves are closed; the point right after the compression stroke and right before the injection and combustion stroke (I think).
If both of the valves should be closed, couldn't I test the current position by blowing air into the cylinder? If the cylinder is sealed (both valves closed), it should pretty much hold air. If it were at the opposite TDC, the air would flow out because the intake valve would be open. Would this test work?
Or, since it won't damage the pump, if it runs, but no power, I guess I could back off the pump and rotate it 180 degrees to the other TDC. It would be nice to have it close to the right spot though by the time it is ready to go. Currently, the injectors are in the shop for testing.
Post a Followup
