Re: Bad Day for my 400.
Posted by andy r on July 05, 2005 at 22:45:48 from (69.66.148.6):
In Reply to: Bad Day for my 400. posted by Kelly C on July 04, 2005 at 21:57:50:
You can put in a newer PTO unit. The later 560's had a unit that snapped in and out rather than the lock in and out with the thumb button. I assume it might be a better PTO. Actually I think a good functioning unit even like the one on your 400 should carry all of the horses you have to the baler. Maybe it was wearing down. If you make a swap make sure it will give you 540 rpm at your rated speed. There are differences between diesels and gases I do believe.
Post a Followup
