Re: IH 806 stopped running
Posted by Turk on July 06, 2005 at 10:17:43 from (206.222.209.4):
In Reply to: IH 806 stopped running posted by Rene Ehrhardt on July 06, 2005 at 07:56:00:
My 806 did the same thing on a silage blower, got weak and died. It would light up and run a little bit and die. Lots of flow through the filters. It turned out to be the little glass check ball for the return line on top of the fuel pump, a RoosaMaster. I took the check valve off and it would run just fine. Replaced it and it was fixed. But be sure you have good fuel flowing through good filters FIRST, if you don't have Diesel experience the fuel pump is NOT a good place to experiment. Very durable tractor, get the bugs out and you will most likely become attatched to it. Bill
Post a Followup
