Re: 560 engine problems well sort of a 560 that is
Posted by El Toro on July 06, 2005 at 16:49:20 from (152.163.101.13):
In Reply to: 560 engine problems well sort of a 560 that is posted by old on July 06, 2005 at 15:21:51:
Hi Old, You can check for spark yourself by removing the distributor cap and remove the coil wire from the cap and hold it within 1/4" of ground. Turn on the ignition switch and with points closed, snap them open and close a few times and see if the coil wire is firing nice. Does it start after sitting for awhile or when it cools off? No fire present probably a weak coil.
Hal
Post a Followup
