Re: valve lash specs. farmall h/ air cleaner tube
Posted by El Toro on July 07, 2005 at 03:50:18 from (205.188.117.73):
In Reply to: valve lash specs. farmall h/ air cleaner tube posted by Greg Wilson on July 06, 2005 at 22:41:19:
The valve lash is .017" Hot. I would set them at .020" cold if you've had the head off, until you get the engine running. Hal
Post a Followup
