Re: 656 gas engine - won't run
Posted by Aces on July 08, 2005 at 06:54:32 from (4.164.18.131):
In Reply to: 656 gas engine - won't run posted by Michael P. Deslippe on July 08, 2005 at 06:41:43:
Michael The 656 has a 12 volt electrical system When you start the engine it gets 12 volt to the ignition by way of the starter selenoid after it starts and you let off the starter button it goes to less voltage through the resister. When they start and die the 6 volt side as it is called is not working. First check the retister.
Post a Followup
