Farmall C Charging Problem
Posted by Brian Schmidt on July 09, 2005 at 20:18:12 from (12.207.196.250):
I have a 6V C that has worked well for several years. Recently it has stopped charging when I first start it. I have to polarize the regulator every time I start it to get it charging. I have changed the battery as it was old and changed the regulator. I have adjusted the spring that cuts the gen out when you shut it off as loose as it can be and still open up when it shuts off. I can push this down manually when it is started and it will hold. It just won't pull it down on it's own. Once it starts charging, it works well. What have I missed?
Thanks in advance!!
Post a Followup
