Re: Farmall A wiring / 'A' connects to 'GEN' termi
Posted by Bob on July 10, 2005 at 00:24:40 from (64.21.249.40):
In Reply to: Re: Farmall A wiring / 'A' connects to 'GEN' termi posted by Kendog on July 09, 2005 at 18:13:18:
If it still doesn't charge, ground the "F" terminal at the generator, which will "full field" the generator, which should make it charge at full charge, even if there are problems in the voltage/current regualting section of the regulator.
(Do this for a short time, for testing only. Do not continure to operate it full-fielded.)
Post a Followup
