43 H – What is in front of the Mag
Posted by ChrisL on July 10, 2005 at 05:46:33 from (205.188.117.73):
What is the component in front the mag – believe it is a pump – is it part of the lift-all system
What fluid goes into it – it is dry
what’s it’s function, there is a lever attached to a rod that goes to operator area
After a qucik look in the manauls I saw no mention of it.
Post a Followup
