Re: Super A Transm/Diff Oil Viscosity
Posted by Hugh MacKay on July 10, 2005 at 13:18:23 from (209.226.247.171):
In Reply to: Super A Transm/Diff Oil Viscosity posted by Bud W on July 10, 2005 at 12:01:22:
Bud: Since your tractor only holds 5 quarts, it's not an expensive change. I always put 6 quarts in there. Yes I would go with the 140 in your heat. You may find this doesn't help as there may be bearing wear. Check the final drives as well, about the only way to drain those is take the pans off the bottom, they hold 3 pints each and that is over and above transmission.
A good way to check for bearing wear and zero in exactly where it is is use a stethescope. Good way to check rear axles is jack and watch wheel and axle in relation to final drive housing.
Post a Followup
