Re: farmall 350 hydraulics
Posted by Peter B on July 11, 2005 at 16:46:24 from (68.254.59.48):
In Reply to: Re: farmall 350 hydraulics posted by TDK on July 10, 2005 at 18:23:13:
Thanks to all who responded. After reading the follow ups, I went out to the shop this morning and stared the tractor. Same problem. I looked at all 3 valve selectors and they all were fully engaged in the "DOUBLE ACTING" detents. I moved all three to the "single" detent and then back to the "double". Started the tractor and prblem was GONE. Cycled all levers several times and everything worked. Must have been something hung up in on of the valve selectors. Thanks again everyone. P.S. the orfice and screen that TDK talked about is located BETWEEN the 2 large bores in the regulator valve. The picture in the manual makes it appear to be under the spring and rider but it is actually next to it. I already had that part and cleaned the screen and made sure the orfice was open. Thanks for everyones help.
Peter B.
Post a Followup
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
