Re: F-20 piston removal
Posted by R-cubed on July 11, 2005 at 17:58:07 from (209.30.148.214):
In Reply to: Re: F-20 piston removal posted by El Toro on July 11, 2005 at 08:35:29:
I wouldn"t want to beat on the actual piston top even if you are not going to use them later. Once you break thru the crown further hammering is a lot harder. I would get a large round block of wood like a section of a oak limb about 6" long just a little smaller than the bore and flat on the bottom. (if you have flat top pistons. That way it puts the force even on the piston and is less likely to break it.
Post a Followup
