1066 Draft Sensing Issues (long)
Posted by Pete in Tejas on July 11, 2005 at 23:44:28 from (67.172.196.120):
I"m new to the world of red after tiring of borrowing, breaking and fixing my cousin"s JD"s. Unfortunately, after purchasing my 1066, I have yet to work it as it was designed due to the annoying repairs that always seem to be missed when looking it over before the purchase. Only being able to go to the farm on the rare weekend and waiting on parts has also slowed the process as well. This started out as a simple fluids change and minor repair session. I ordered and replaced the right hand lower link on the 3 point since the inside ball socket was blown out. When I pulled the arm, I noticed that the RH crank arm was not lining up and the block was not in the slot, it was moved to the left about 1/2 an inch. Here"s where it started getting ugly. The crank arm had been run for some time without the block in the slot and the splines were worn at an angle and only held in place by the torsion bar anchor bracket. The torque tube looks fine fortunately. The tube did not want to move to the right so that I could get the block into the crank slot. I was desperate, and thought that the u-bolted arm inside the case was some how binding and not allowing the tube to move to the right. So I pulled the PTO unit since I was changing the fluid anyway, putting it back in is another story. The inner sensing arm was u-bolted almost all the way to the left, so that didn"t seem to be the problem and with some persuading with a block, large hammer and a prybar we were able to center it. Now I am concerned about the u-bolted sensing arm and how it rests on the lever up in the frame. When the crank arm is pushed forward the sensing arm pops off of the lever. Is this normal? Also the draft adjusting lever in the cab is spring loaded and stays forward. Is this normal? I wasn"t able to run the tractor since something must have been left on and the tractor was un-jumpable. Will the hydraulics change the draft adjustment operation if the tractor is running? Also when I put the draft sensing tube and crank arms back together, there was a little preload when I put the torsion bar bracket on and the gap between the right crank arm and the stop adjustment is about 1/2 an inch. I am also fairly confident that the sensing arm will slip off the internal lever if I push the arm all the way forward. Have I done anything right? As you can tell everything went about normal for a project like this, the manuals are of little help and I am, to say the least, discouraged. Any input would be appreciated. Pete
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
